- Joined
- 11 Dec 2012
- Messages
- 5,246
- Reaction score
- 2,716
- Country
It is. What should I expect to happen?
Usually, you dont put kitchen units on a floating floor as it needs to be able to expand and contract.....
Was the flooring stuck down or not?
No, it is LVT clicking floor, so the panels are connected with each other but they are not glued to the screed.Usually, you dont put kitchen units on a floating floor as it needs to be able to expand and contract.....
The plastic sheet is tiny, I think their point was that the self-levelling compound would be too thin to hold it down properly. And yes, they also removed the tarry layer.I can't see the lack of DPM causing problems unless the pre-existing tarry layer was also removed in those same areas, or if rising damp is already a problem. But the builders excuse of there being 'no room' to lay the DPM doesnt make a lot of sense because even the heaviest gauge plastic sheet is only fractions of a millimetre thick.
Sorry for the stupid question, but what would have been the correct way to do this? In case it changes things, it wasn't just a few mm of self-levelling compound, it was maybe 3cm or so, so still a quite solid layer.He poured floor levelling compound directly onto a plastic sheet?
I'm a wee bit baffled...
Thanks, interesting point. I thought I only had the bitumen dpm in the kitchen because that's the only place where I had seen it, maybe we didn't dig deep enough in other rooms. It's too late to check the other rooms now. Anyway, I'm really only worried about the kitchen because that's where I know for sure that we had this layer and removed it without installing anything new.Most if not all houses I worked on, same age as yours, have a bitumen dpm below the screed.
Yours is probably the same.
You could core a sample on a hidden corner to be 100% sure.
