So I think we’ve made a silly mistake and need some advice on the best way forward. We’ve recently had some renovation work done and to level the garden we had a retaining wall built and the builders rubble back filled the area. There’s enough room for approximately 10cm of topsoil which the builder thought would be ok for grass however we want to plant more than grass and also after researching I’m realising 10cm is not enough for grass anyway.
How should we proceed?
Is there a depth we should dig down and remove rubble to? I’ve seen some posts saying approximately 90cm of topsoil should be fine, not sure whether to remove 90cm of rubble from the full lawn area or just the borders for planting?
Also thinking hiring a digger is going to be the best way to remove such a big amount?
Any advice would be much appreciated
Thank you
Thank you
