Building a backless wardrobe in front of a fire door
  • Thread starter Thread starter JPJ
  • Start date Start date
JPJ
6 Jan 2013
London
I'm moving into a new residential duplex flat, and the upper floor has a fire door in one of the rooms.
I would like to maximise use of the space in that room, and have plans to build a wardrobe in front of the fire door with space only for hanging clothes. The wardrobe will have floor to ceiling doors installed.
It is my intention to leave the back of the wardrobe open, so that it provides access to the fire door (which opens outward into the stairwell) - think Narnia.
Therefore, in event of an emergency, the hanging clothes can be pushed out of the way or easily pulled out and put to the side, leaving clear access to the fire door and hence the escape route.
Does anyone have an opinion as to if this sounds reasonable, and also know if it is within regulations?
imagine the scenario
thick black acrid smoke on you hand and knees your last few breaths ----- :oops: :oops:
the regulations say something like clear unimpeded but may be different in your case
There's no doubt whatsoever that it infringes the Regs, contravenes the terms of the leasehold and your own insurance.
Trouble is people do think it will never happen to them and in a couple of years when the rail is jammed full of clothes and there's a load of old shoe boxes stacked up against the door when as mentioned you are gasping your last few breaths, you heart is pounding at 200bpm and your brain is half asleep because your smoke alarm has just shocked you awake (its pitch black too btw) if you think it will be no problem then go for it.
It's the worst suggestion I've heard all year.
