- Joined
- 10 Sep 2015
- Messages
- 18
- Reaction score
- 1
- Country
I'm looking into building a garden room against my house out of mostly reclaimed materials, some of which I'll already have here - I've got a 50mm thick conservatory roof in the garage that's the size I want (approx 4x4m) and I'll have my old double glazing to use for the front and side walls too. End wall would be solid.
I'm wanting to build it on the side of the house and get french doors installed for access. So it's turning into more of a conservatory, really...
Anyhoo, my plan is to build a sturdy wooden frame and a part wall around the base, as I won't have enough windows to do full walls.
I'm just after advice on how best to join everything together, and how to build that part wall for best insulation. I do not expect a warm room! But "not as cold as outside" will do. I should have the joining pieces for the roof in the garage with the panels but I think I'll probably have to replace those as it's been in there for a number of years now.
Any other advice welcome too! It'll be under the maximums for planning permission and won't cause any issues for my neighbours, because they've got a massive extension on their side of the fence in the same place which is bigger than my room will be.
Budget flooring suggestions also welcome please! I'm planning on doing concrete footings for the support beams because the solid here is very sandy, although the area does have a fine gravel base under the weeds from a patio that I moved when I first moved in.
