Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
What width and depth should i do foundation for a garden wall if building on solid limestone rock 2ft down, read somewhere make it 600mm if double skinned and 375mm depth if wall is over 4ft but do i really need it 375mm if im building wall on solid limestone rock?
If the difference in level is not too much, can you make it up by mortaring in brick/tile etc in any hollows, rather than pouring a level concrete strip right along?
I could but its not the cost of concrete foundation thats problem but if it dont need to be as high as it would be on soil base id rather not have a higher than needed being on limestone rock
