- Joined
- 18 May 2025
- Messages
- 2
- Reaction score
- 0
- Country
Hi
Thanks in advance for taking the time to read.
About our property
A significant portion of the property is single storied. This must have been the parts where the property was extended over time. The original structure is double storied. As a rough estimate, the first floor square footage is half of the ground floor's
Brief Description of Project
We have received planning permission to extend the property. A summary of the change to building
Ground Floor
First Floor
Roof
Trial Pit findings
- Where there is current double storied structure, the half of the foundation exposed (the other half would be inside the property) is 30cm wide x 25 cm deep
- Where there is current single storied structure, the half of the foundation exposed (the other half would be inside the property) is 30cm wide x 30 cm deep
The structural engineer advises us that we'll require underpinning.
Question
To me, as a layman, where the existing double storey structure is supported by a 30cm x 25cm foundation, it's not clear to why isn't the 30cm x 30cm foundation on the single storied side not sufficient when extending to double storied.
Thanks and regards
About our property
Ground Floor
- Retain the existing footprint- Remove some of the internal load bearing walls for a more open plan design. Steel beams will replace the load bearing walls- Some reconfiguration of roomsFirst Floor
- Extend over the downstairs footprint, adding more rooms- Two steel beams added to support the structureRoof
- Replace the existing roof to make it one single roof.Trial Pit findings
Question
Thanks and regards
