Hi
I'm rebuilding my shower which leaked terribly after having it professionally done in 2018. This time, i'm doing it properly using backer boards (XPS) and tanking on top of those. Belt and braces. Its going onto a solid concrete floor so needs to be elevated.
Unfortunately, the mira flight shower tray riser kit I already bought can't be used (pipes etc), so i'm building a base. I spoke to Mira and they said to use minimum 22mm marine ply. I've got regular ply 18mm on hand. I'm wondering if i can double up the 18mm ply to make 36mm but if so, how would I fix the two pieces together?
Also is regular ply okay? Its got to be better than the chipboard the pro's used last time. I was thinking i could prime the edges with silicon or SBR (?) or something else.
Btw i also bought cement to bed the tray onto the ply but Mira are saying to use silicon.
thanks
mike
thanks
mike
