Hi, so I'm going to be building my own shed. I'm planning it now. I recently went down to a shed place local to me, thinking "how bad can they be?" Well, if I want a shed made of balsa wood I know where to go.
So anyway, this shed I'm planning. It's going to be approx 16ft x 10ft with the side walls 6ft6 high and an apex roof to about 8ft high (or whatever looks "right" for the roof slope).
Its use will be varied. There will probably be a fridge, freezer and dryer in there, a workbench and storage for tools, bikes, garden stuff etc. We're having a boy in July and I want somewhere to "bond" with him when he's older. I hate all sports so I'm thinking some hobbies like electronics, model building etc, might be something we could get into. If not I've got a bloody good man cave.
My plan is to build a wooden insulated platform framed in 6x2 on 6 legs or piers (snooker table type layout). Surface this with 18mm ply.
Then I will build 6 frames (two each for the long sides and one each end) in 4x2 and join them all together with 4x4 fence posts (set so that these are visible on the outside and the cladding will butt up to them). The frames will be faced both sides with 12mm ply and insulated with kingspan. Does this need a vapour barrier? Inside or out? I will face the outside with horizontal featheredge. The two intermediate fence posts will be jointed together firmly at the top to prevent spread and give a middle support for the ridge beam.
For the roof, I intend to fix a length of 6x2 end to end at the ridge, then cut each of the 4x2 rafters to suit at 2ft intervals. Surface with 12mm ply, insulated with 100mm kingspan and fix 12mm ply underneath too. Does the roof need a vapour barrier?
I'll then wire it up and fit it out internally. I might even paint it inside. For the doors and windows, I plan to get hold of second hand uPVC units.
Could I use cheaper sheet material such as OSB anywhere? Or everywhere?
I've just priced up all the plywood I need and it'd cost over a grand just for ply (B&Q prices).
Is there a better way to do anything I've said here?
Are the timber dimensions I've quoted sufficient?
For the roof, I want to use felt shingles - I will lay a layer of normal felt under this. Should I use adhesive? Is metal sheet roofing hard to work with? A local shed supplier offers this as an option.
Thanks for any suggestions!
Steve
Steve
