I'm planning on taking my current shed down and building a summer house type shed in the garden.
Here is a plan of my garden:
The 4.5m and 4.8m are garden width measurements (garden tapers narrower towards the back). The black pen "example" is the most likely size of the shed (3.8m x 3.9m).
1). a). The "shed" will be built from 100mm thick aerated blocks. Would a concrete foundation of 100mm thickness and footings of 450mm depth suffice for this type of build?
1). b). Can I mix old pieces of concrete and stones I have laying about in the garden to the concrete mix to save on costs? Should I thrown in some metal grids and do I need any expansion joints? I have mixed old concrete before into the foundations of a retaining wall without any problems.
1). c). Do I need any type of damp proof membrane under the foundation? For example: Dig hole, compact, lay DPM, add concrete over DPM... or should the concrete slap be in direct contact with the earth and the DPM added after (over concrete, under interior floor)?
1). d). Am I expected to lay the footings and base slab in one go to ensure they are all 1 piece of concrete? Or do I lay the footings first, wait to dry, then the 100mm thick base slab inside after?
2). I had an idea of sinking the shed into the ground (to allow greater height inside). Is it a good idea to start the build, from say, 30cm below the earth's surface or would I run into too many problems with damp etc...?
The aerated blocks will have a 45mm stud wall attached from the inside with insulation panels - this will also be the case for the floor (Celotex). Walls will be plaster-boarded and plastered. Exterior walls will be rendered.
Thanks in advance.
Thanks in advance.
