Building timber window frame
14 Mar 2013
Manchester
Hi folks
I have a large double-glazed unit (80x200cm, no frame) left over from patio door replacement that I'd like to use as a window in a shed/workshop I'm building. The most useful guidance I've found so far is this little diagram from David Stiles' Sheds book.
Won't bother with muntins, but I think I can handle the joinery here. (Though any comments welcome.) Should I make the space for the glass a few mm bigger than the glazing all the way around? Mostly I'm wondering about sealing. In the diagram below I've coloured red where I'd expect to put clear silicone sealant, and blue where I'd put some sort of tape. Does that look right?
And if so, is this the sort of tape to go for? - link
A couple of other questions. Can I rely on the silicone as adhesive for the beading or also nail in? And when I fit the frame into the wall, using spacers to fill gaps between window frame and wall frame, should I fill gaps with expanding foam? (Gripfill?)
That's probably it for now, though suspect other questions will come up soon enough. I'm probably plunging out of my depth with this.
Cheers
Kev
Needs to be taller than glass so in can sit on raised pads to prevent it sitting in water, also a few drain holes from base of glass to the ouside to drain any rain getting thru.
You have it back to front, beading on the inside , more secure and simpler to seal the outside as there is only one seam to seal.
Needs no sealant on beading as it will be inside.
