Building up floor level
15 Jun 2020
Hi all
Looking for a bit of DIY flooring advice as I've not really gone below the top layer before.
This is in a 3rd floor flat where I've quickly rolled back the floor covering (Carpet & underlay) to investigate a badly uneven section of floor in a small bedroom and found the following:
2 x layers of 5mm fibreboard
A layer of 18mm T&G board that looks like it's had water damage at some point. Someone has replaced a single section using board of a different depth (15mm) o_O causing the squeeking and uneveness
A layer of paper backed fibre insulation - which is pretty much ruined
Finally another layer of board, which actually looks ok, feels solid and doesn't squeek at all. This is screwed to the joists.
The higher T&G board layer was screwed through the fibre insulation and into the subfloor.
I'm thinking of keeping the subfloor as it seems fine (at least in the small section I've revealed) , but obviously the insulation upwards is all getting binned. However this leaves me with about 32mm to fill to get back up the same level as before, otherwise there will be a step-down through the doorway.
Whats the best approach? Some kind of sound insulation then a floating chipboard on top?
Cheap solution could be something like this in two layers, one below and one above a 23mm T&G board?
https://www.screwfix.com/p/vitrex-p...6m/68038#product_additional_details_container
That would get the height right but not sure it's the correct use. Covering will be carpet
