Built in wardrobe problems
1 Aug 2011
Gwent
I have just pulled down some built in wardrobes I had built a few years ago. They were built across a chimney breast across the entire wall, upstairs, on the pine end of my 1920's house. There is no wall cavity and the chimney has been closed off. After around a year, clothes started growing mould and the bedroom stank of damp. On closer inspection, I could see that the alcove areas at each side of the chimney were black with damp. Someone recommended that I dry line the pine end wall with green board (it has been dry lined once though) before re-installing the cupboards. I don't want to risk putting them back up in case it happens again even with the green board. Can anyone offer any advice on this please? Should I have put some sort of vent in the cupboard wall to let in air circulate maybe?
Chimney breast should have a vent if it's not in use and also be capped to prevent rain entering and causing damp in your cup'd.You need to check the roof for damaged flashing etc as the cup'd may be hiding a minor leak.
Any new cup'd should be ventilated.
