Yes! I thought it would be a simple matter of adding some to water,but, my stuff doesn't do that!
My product bostick cementone plasticiser says 85 ml to 25kg cement!SORRY - I USED THE LINK FROM 'LOST IN THE LIGHT'.
NOT YOUR PRODUCT - What product are you using?
BUT I WOULD USE TE NUMBERS BELOW AS WILL BE CLOSE ENOUGH FOR YOUR NEEDS
Yes it does. The spec you sent says:
Dilution: 1:30 Sovereign Waterproofer to fresh clean water.
So make up a bucket/tub of water to be used to make your mortar/concrete and add:
1 litre of Sovereign to 30 litres of water
or
1 ml of Sovereign to 30ml of water
or
33 ml of Sovereign to 1 litre of water
or
333 ml of Sovereign to 10 litres of water
SFK
where's the .55 coming from?Eamman,
Got it.
So using the assumption that:
water to cement ratio should be around 0.55.
If your total cement requirements were 25kg (one bag), then the calculation would be: 25kg x 0.55 = 13.75kg (liters) of water.
So for every bag of cement you use you need ABOUT 14litres of water.
As it states 85ml to 25kg cement
So if you wanted to pre mix your water then put 85ml into 14litres of water.
Or 6ml into 1 litre.
Or 60ml into 10 litres.
I know I shouldn't say this but Bostik say not to add it to water! but,I can't see how else to add it!Eamman,
Got it.
I was going to use a cap full ,as I know NOT to put a lot in in case of issues! Are you a builder???Eamman,
Got it.
I know it says mix into the cement, but
adding to water for your use will be easier and
these numbers will be close enough and will work without issue.
SFK
As you need 85ml for every 25kg bag of cement, yo have a few methods:but,I can't see how else to add it
Unfortunately,I don't have a weighing scales for that,I might try the 6ml to a litre of water, though! Surely it can't be far off that!As you need 85ml for every 25kg bag of cement, yo have a few methods:
1) Use quarter a bag of cement
and add 21ml
2) Use half a bag of cement
and add 42.5ml
3) Go outside and stick your spade/shovel into your cement.
Weigh how much cement you have on your shovel.
For every 1kg of cement on your shovel you add 3.4ml
SFK
Eamman,6ml to a litre of water, though! Surely it can't be far off that
Nope, 3.4ml into 1kg of dry cement would disappear like tears in the sun.if there was too much plasticiser in the mix would it show when mixing with the dry mortar
