Burglar Alarm + problem
  • Thread starter Thread starter timmyquick
  • Start date Start date
T
timmyquick
I am trying to set up my brothers burglar alarm, he has a Texecom veritas 8c Compact all the sensors have now been wired to the panel using the wiring diagrams & colour code from texacom all the pirs & door contacts are texecom so was very simple to do, but am confused about how to do the alarm box. On the texecom panel the connections are :-
A= Permanent Positive Supply (+12V)
B= Switched Negative to Activate Sounder
C= Negative Tamper Return
D= Permanent negative Supply (0V)
S= switched Negative to Activate Strobe
However on the Icon Alarm Box that my brother has bought it has six connections and not 5 also the lettering appears to no mean the same i.e
A= Permanent 0V from control Panel
D= permanent 12V supply from control panel
B= Switched -VE or 0V trigger4 from control panel
T= -VE tamper return to control panel
Then there is 2 symbols for strobe + and strobe _
Is it possible to wire these different makes together? if so how? or is a different alarm box required
Panel________Bellbox
A___________D
B___________B
C___________T
D___________A
S___________-STOBE
Connect the terminal in the bellbox marked +strobe to terminal D in the bellbox allong with the cable from the panel (two cables in this terminal).
