Burma teak garden bench
2 Nov 2005
I have been sanding down a garden bench which is badly weathered, green bits (mould?) and which was painted with a dark stain, now flaking. I have uncovered (under the stain) a plate advising the wood is burma teak.
If the bench was mine I would rub down to remove as much stain as possible and treat with teak oil, however, it is a part of gardening work I am doing and to spend a lot of time on it would be to expensive for my client (OAP).
Advice I would appreciate is that If I take the worst of the stain off but not all (ie that which has soaked in) and then treat a test area with teak oil to see how it looks, if not okay, would a stain take on top of the area treated with teak oil and if not, how best to remove/neutralize the teak oil.
Also, if it is okay with teak oil, how often does it need to be re-treated with teak oil to maintain a neat finish.
Do you have a powered sander? Screwfix are doing one for £3.99, and would make light work of a bench..
Hi Deluks
I am using a Bosch orbital sander and course elctro coated resign bonded sand paper, also a lot of hand rubbing. Flat bits are fine but but there are a lot of places the sander is to big eg. edges of the slats on the back, also where the slats join; same for seating slats. Also the seating slats are not set dead flat but on a curve.
thanks for interest.
Stanrog
Teak is naturally oily, so other stains and paints will not adhere well.
Is the old chap not capable of doing a bit of rubbing down on his own?
Thanks for reply JohnD. The bench owner is a female OAP and she does not have the strength to do any sanding.
Regretfully, it does seem that I am going to have to stain it.
regards
Stanrog
