Hi there. I am having my electrician install some new downlight circuits, but I want to make sure I get the right stuff, last time he did this the switches buzzed loudly, as did the light fittings............
What's the magic formula? I wanted 3 circuits in total, 2 with 5 x 50W LV lamps and 1 with 4. I've read somewhere that the dimmer switches need to be rated at twice the total wattage, so 500W? Also do I need to make sure I avoid cheaper transformers? If so any recommendations?
I'd like the dimmers to be mounted in line next to each other, but using larger capacity dimmers will space them apart and take up loads of space on the wall, is there anything else I can use to get around this?
Many thanks.
Many thanks.
