Buzzing from ceiling light
9 Nov 2003
I have a ceiling light that is making a buzzing sound when switched off.
I have checked all the connections in the switches (it can be switched on & off from two locations) and ceiling rose and they appear fine.
It has made the buzzing noise ever since I moved in but the light has always worked fine - doesn't blow bulbs or trip the circuit - so I haven't worried much about it.
Can anybody shed any light - (sorry) - on this for me?
if it is a humming noise it could be that it doesn't know the words. :lol:
is by any chance a low voltage light?
Yes it is one of those energy saving 13w bulbs.
But I have them in other rooms and they don't hum. The only difference is they are 1 way whereas the problem one is a 2 way- actually it is a 3 way as it has an intermediate switch as well.
sorry to be "picky" but energy saving lamps are NOT low voltage. what happens if you put an ordainairy clear (not frosted) lamp in? doesn't slightly glow does it? (you may need to look at the dead of night)
also what happens if you try a different energy saving lamp?
what happens if you put the buzzing energy saving lamp some where else does it buzz?
If I try that energy saving bulb in another light it does not buzz.
If I put a non-buzzing bulb from another room into that light then it does buzz.
Also no bulb at all then no buzz (but that is probably obvious)
I will have to go and buy a ordinary clear bulb first before I can test that scenario. Check back tomorrow for results.
Actually it doesn't! Put a 60w clear bulb in and NO buzzing, can't see any glow either. Put an energy saver in and it does buzz.
I will check the connections in the lamp holder anyway. Thanks for the pointer.
