cable for outside lights
S
skwirrel
Hi All
I need some advice - I've just moved house and was checking the lights on the back of the house two cheap bk/hds that I've removed. They were connected with flat twin lamp flex!!! which has perished. The cable was fitted to the wall. I want to put some new lights up need some advice on cabling for the outside.
1.Do I need to use SWA which is a bit bulky even at lowest rating.
2. What's a suitable alternative
NB I can't access through the wall as house is newly decorated and upstairs is all new flooring - previous owners must have been 'House Doctor@ fans. But bodged on electrics.
I am also considering LV lighting for simplicity as I only require mood lighting (not my bad mood!!!)
I am not a fully qualified leccy but I am an Electrical/Electronic Engineer so I no about safety aspects etc
Suggestions please
TIA
Skwirrel :mad:
What about FP200 cable.
How did you remove the old wiring - did you just cut them off flush with the outside wall?
No I may be daft but I'm not stupid. Traced cable back to socket behind TV.
provided you aren't burying the stuff i would use arctic blue
fp 200 (well almost)
artic blue (also available in yellow)
Breezer, you are correct, arctic cable is available in Blue and Yellow, however Yellow is for 110V supplies only and should not be used for mains voltage.
Sqwirrel, I would go with FP200, it looks better for permanent installations exterior to a building, if it is ever painted it will not be degraded, arctic blue will crack if the wrong paint is used as it is not designed to be painted, and FP200, being stiffer, can be clipped more neatly on a surface.
If you still wish to run this lighting via the ring, then you will need to introduce a switched, fused spur to the ring, and use this to power the lights, after replacing the fuse with a 3A.
Thanks All
FP200 it is and it will blend in with red brick work although I notice theres no price in the TLC catalogue must be expensive.
I'm going to spur off from downstairs lighting circuit and fit an out side IP56 switch.
Cheers
Dave
the catalogues i have seen have listed the yellow arctic cable as being identially rated to the blue stuff
useing the yellow for 240V could give the wrong impression though
