Are the cable and pipe finders reliable in locating gas and electricity supply cables in the ground inside a property curtilage?
Like this one you can hire from HSS:
https://www.hss.com/hire/p/cable-and-pipe-locator-cat-3-hire-pack-1
I need to replace a section of water supply pipe, and probably hire a micro digger if I don't want to break my back.
Having done some previous drainage works, and having a near miss with both services which were basically laid immediately beneath a clay drainage pipe running to a soakaway. I therefore know where they are near to the property, but it would be a complete guess as to their run down the drive and exit to the street.
I obtained electricty and gas plans last time, but they were totally useless and simply showed a layout of the mains in the street and no detail even of connection points for the property. The property is 1930s and probably original infrastructure. The gas is still iron pipe unsleeved.
