Dear All - you advice is welcomed.
I wish to install a WC in an en suite BUT the room is located at opposite end of house from soil stack and lands to this gable are not in my ownership. Added difficulty is that 5 inch joists run front to back and if i were to pipe saniflo macerator internally i would have to drill out all the joists which even if using 22mm pipework i guess would affect their integrity.
Therefore proposal would be to discharge externally and trench around property and into sewer. Approximate run is 3m fall and then 30 metres vertically all laid to correct fall. My question is does this sound feasible and if so do i have to use rigid 32mm pipe beneath ground or can i use mdpe pipe.
thanks
thanks
