- Joined
- 8 Mar 2010
- Messages
- 336
- Reaction score
- 8
- Country
What ho one and all,
Sad that I should be writing this on Christmas Day, but what else is there to do?
In the past, I had a secondary income from photography and have a old(ish) studio flash pack with three lights. The pack is basically a floor standing capacitor. Having been asked to do some portraits after Christmas, thought I would check out the gear.
Unfortunately over the years, (and lack of use) the flexible rubber insulated cables from the flash heads have become so brittle that they are crumbling.
So my plan is to replace them but am having difficulty finding the right stuff. The cable is six core with an outer diameter of 11mm. Each core has an insulated diameter of 3mm and any twisted core (tinned copper, about 23 strands) is around 1mm o/d.
Simple maths reveals that the mm2 is 0.78mm2 so I presumably and cable with 0.75mm2 is correct?
The plug says 250V / 6A Again, a calculation reveals that with a max output of 800W (this would be full power to one head; use two and the output is halved to 2 x 400W) the amps is 3.2A.
And so to my question: I have found a supplier of 6 core, multi-strand tinned copper, 0.75mm2 and advised that the rated voltage is 450 - 750V. Is this likely to be OK?
One little 'but.' The old brittle cable has on o/d of 11mm; the new stuff has an o/d of 7.5mm. In itself, not a problem but would this imply that the cores are too small and I should go with the 1,,2 cable?
Thanks for toodle pip
