I realise that the single cable loading on a 1.0mm circuit is 1200w.
However, if you use circuits as a ring then am I right in assuming that you can double your loading as you've effectively doubled the conductor area?
Also, if so, would it theoretically be safe to run a 2.5mm (with loading of 2400w single run, 4800w ring), In a single run to the ring main of the lighing circuit?
Any ideas/Sugestions welcome.
earnie
earnie
