Hi guys
I have planned a power system to the brick shed about 4 metres from a house. Can you tell me if it's right?
2.5mm SWA from the house to the shed terminating in the shed in the form of a metalised 13A fused switch. The fused switch then feeds 2 sockets in a radial circuit. In addition it also feeds a light via another 3A fused switch.
The supply will have it's own breaker in the CU. I have a spare 32A MCB at the moment on the RCD side of the CU. Can I use this?
In the house I was planning to terminate the SWA below some kitchen units into a JB. This will then provide a standard 2.5mm T/E feed to the breaker at the other end of the house.
I am planning to use 3 core SWA to provide me with a sleeved earth connection via the junction box as well as the metal FCU with the armour providing a further earth to the metal back box.
Is there anything I haven't thought about?
