Calcium Carbonate or limestone help
4 May 2015
Devon
Hi
I am really struggling to remove a substance from the bricks on an outside wall. I have tried regular brick cleaner and it hasn’t touched it. Now left chiselling for ours at it. Any help really appreciated
I think I know.
Was that section of wall subject to persistent damp, for example from a water leak or spilling gutter?
How old is the house, and was it built with lime mortar?
It looks to me like the water has washed the lime away between the bricks, and where the lime-rich water has evaporated off the surface of the saturated bricks, it has left a hard deposit of limescale. There might be other minerals fom the groundwater. I don't think its lichen.
You really need to clean out the remaining dust between the bricks and pack them with a stiff mortar mix. It is OK to use cement, which will not be damaged by the wet.
Start at the bottom.
If the wall ever gets dry, you can have a go at getting loose lime off with a stiff brush. Don't use a wire brush, which will damage the bricks. The bricks themselves look quite good, although they are as loose as an old smoker's teeth.
You can drill some weep holes, but don't do anything vigorous until you have packed with new mortar, or the loose bricks may fall out.
An acid may help, but I live on chalk, and any crust below DPC is very hard, and I don't try to remove it as vigorous scraping would damage the bricks. I think yours is hard crystals. I believe it hardens by exposure to carbon dioxide in the air.
Occasionally I get weather-induced lime bloom above DPC and this can be removed with a soft brush while it is nothing more than fine powder.
