calculate vent pipe height
14 May 2012
Hampshire
the vertical height is 9m cyl to cwst the temp is 4*c to 65*c how much above the cwst does the pipe need to be
the linear expansion of water is 0.000207 /*c I have used delta t 65 height 9000mm I,m not sure if that's the correct expansion rate will sorry if im a bit abrupt for you dan it,s not intentional its just part of my charm
