- Joined
- 14 Apr 2013
- Messages
- 3
- Reaction score
- 0
- Country
Hi, can anyone point me in the direction of some span and load tables for a purlin.
I'm planning on taking out a second floor wall which obviously currently bears half the weight of the approx 45 degree clay tile batten and felt roof above, I'm planning on installing a purlin prior to removal obviously to take the weight and extend new rafters from that down to an existing ground floor wall. This will enable me to remove the wall and means I can extend floor joists across as we'll and use the existing flat roof as internal second floor space.
If that makes sense, may have just been rambling, it is getting late.
Current rafters span 2.7m and will have to meet new purlin at approx that point and new rafters will have to extend an additional 3m to cover the current 1.8m flat roof, span is 4.7m. But unable to find span and loading charts.
I've found dead loads for roof materials etc which if my calcs are correct work out about 1000kg for total m2 of current roof covering and this will obviously double with the extended rafters as they are pretty much the same length again?
Any help greatly appreciated
