- Joined
- 3 Oct 2007
- Messages
- 5
- Reaction score
- 0
- Country
Our hot water system is not working. I've a Potterton suprima 40 boiler, Drayton LP522 programme unit, 2 x Apcom WH9 thermostats on the hot water tank and a drayton actuator. I recently replaced the pcb on the boiler has i had the common lock out problem. This cured that issue, the new issue i have is that the thermostat is calling for heat but not activating the boiler. I've checked the stat and it's working perfectly. Am i correct in assuming that the call for heat first activates the actuator which in turn calls the programmer to fire up the boiler and allow it to open the HW valve inside the boiler?. I've also replaced the program unit & the wall plate for it.
Any help would be greatly appreciated.....
