i have a baxi 80i boiler
the problem i have is the hot water is not running hot but central heating is as good as it should be
the water will run hot low tap pressure but after a short while it goes luke warm
pressures ok
microswitches seem ok allthough it seems when turned on hot water only it divirts the water down to the central heating
many thanks dane
pressures ok
many thanks dane
