My radiator at the back of the house had 8 mm pipe I connected 10mm pipes to these using olive connectors and teed off the flow and return moving it along the wall then reattached a new rad with new valves and also add another small radiator 3 foot the other way hence the tee both rads aren't heating up I've tried:
Bleeding (buckets out)
Turning all other rads off to move any blocks.
Is it the pipe being 10 mm rater than 8????
The pipe I laid behind the wall isn't totaly horizontal could it be that and there is a 90 degree turn in the pipe ....
Pleas help
Pleas help
