Removing 22mm to 10mm tees from heating pipes
30 Aug 2019
I’m removing my kitchen radiator due to some remodelling; it’s fed by 10mm pipes coming from the ceiling and connected to the 22 mm pipes running across the house.
I’m doing the work from below as the upstairs floor has already been laid and the ceiling is going to be skimmed anyway
The 22 mm pipes run in notched joists and flow and return are very close to each other
I have a few options I think (in order of complexity)
1) cut the 10mm pipes just after the tees without draining the system (just releasing the pressure) and fit push fit end caps, job done?
2) drain the system, cut the 10 mm pipes close to the tees and solder end feed copper caps
3) drain the system, cut the tees using a hack saw (they are too close together to use a pipe cutting tool), cut again using the proper tool, add a piece of 22mm pipe + 2 x slip couples for each pipe
Which one would you go for?
Option 1 is going to be messy, even with pressure released there will be a fair drop of water left in the system. Option 2 is the favourite, 3 is a lot of work and not really necessary on a heating system.
