I have a one gang switch and want to add some wall lights to the room can I just connect into the back of the of the switch? Is there a diagram I can follow?
You need to pick up from the ceiling lights. Logic being that the wall lights will work on the same switch as the ceiling light so are a simple extension of the main light wiring.
Check the wiring at the ceiling light, it's likely to be either a loop in / out ceiling rose or a block of terminal blocks. If so then you run either 1 x wire to 1 x w/light and then another from there to the next wall light OR run 2 x wires from the ceiling light postion, 1 to each wall light.
