Can I fit a hosepipe attachment to this tap? + How to get rid of limescale
OM2
18 Jan 2007
I want to fit an attachment onto a tap and use it with a water hose.
See the pic below
Can I get some sort of universal adapater?
When taking the pic, I notice all the limescale.
How do I get rid of it?
Thanks.
Thanks for the link.
The table doesn't have a thread.
Also it's got an edge cut out - you can see it on the left.
It's a Villeroy and Bosch tap.
I've seen some that you can kind of tighten on with a lever.
I'll try one of those unless someone here says otherwise.
Thanks.
I assume that was meant to say tap.
It does, you unscrew the filter/aerator out of your tap (it will have 2 flats, the one on the left you mentioned and a corresponding one opposite for a spanner to grip) and the attachment screws into the threaded hole that's left.
Guys... thanks for the replies.
I got it off! Erm, I did a super bad job of taking off.
See pic below.
I used a big fat spanner. Is there a special tool I should have used?
+ What is the part called?
I looked up 'aerator' and 'tap filter' I couldn't find anything.
I've fitted the hosepipe attachment thing. Fits nicely. I think I might just leave in place!
"Gel Descaler "
@dilalio - thanks mate. Just what I needed. I need in different places around the house.
When I searched for 'aerator' on its own the search results showed loads of other things. Tap filter the same.
Thanks for the links, much appreciated.
Male and female? Not sure why they are not all of one type? I guess I need male only.
Just wondering...
Is there an aerator that clips onto the hosepipe connector?
I would love to just keep the hose pipe connector on and pull off and on the aerator when I used the hosepipe.
