Can I upgrade only the thermostat from Hive 1 to Hive 2
5 Sep 2012
Glasgow
I have the older version of Hive, with the rectangular white thermostat. Is it possible to upgrade only the thermostat to the newer more modern shiny square silver version? I think the hub and receiver should be compatible but not sure.
Also, mine is the type which controls the DHW and CH (dual channel) - should I be looking for a specific thermostat or are they all the same?
And finally - do they come with a fixing plate to affix to my existing backbox?
TIA
I upgraded from v1 to v2 when it first came out and still have the v1 hub and it all connected up ok.
It came with the wall mount as well.
Mine is single channel but I think the thermostats are compatible for both
