Can i use a sander to remove too much filler on wall?
11 Jun 2012
Hi, I have a problem area in my new build house in the living room where from the bottom of the skirting board and then up about 1.25 metres a crack always appears in the plaster board, this has been fixed a couple of times by the developer and i have also tried doing it a few times but always comes back, the last time i tried to do it i put a fair covering of filler over the area and i got it its covered more than i wanted, i also left it for a bit too long because io had to do something else and by the time i got back, it was dried. i tried to smooth it as much as i could with a hand sander but it proved a bit too much to do.
My question is can i use an electric sander to do this, would it have to be very fine sanding paper if so?
Below is a pic of the area i mean.
eWNdjy
eWNdjy
https://ibb.co/eWNdjy
James
Course sanding paper would be better - switch to fine when it’s almost flat.
Just done some similar work - a random orbit sander from Screwfix (£40 ) with the dust bag removed and a silicone hose pushed on the stub - one off use could be duct tape - connect to vacuum cleaner. No dust escaped ! It will get used a lot in future
