can I test an immersion element and stat with multi meter
Yes, turn the local switch off and check there is no power using a multimeter.
With the power off set the meter to continuity and see if you have got a circuit across the stat , if water is cold you should have a closed circuit, if its ok check the resistance across the element ,you should get a reading of between 15 and 20 ohms ,depending on your element.Your thermostat may have a cut out on it also to prevent the cylinder boiling if the stat fails and this may just require resetting.
If you are in any doubt about any of this do not even attempt it!
No you said yes that the op could test an element with a multi meter, when really they can only test certain things not all!Vibro,
It wasnt meant to be a step by step guide it was a brief overview of what could be achieved with a multimeter.
Was not obvious in the op. Could quite easily have been no voltage to the element could it not. You should not assume that it has been tested when not specified.I presumed that the op had already tested for power as he only asked about testing element and stat not voltage.
Not entirely true starspark1. Surely the RCD could trip for other reasons when the immersion is drawing a bit of current, wouldn't you say!Also if the RCD was to operate i think that would point to the fact that the element was faulty providing it didnt trip until the immersion was energized.
Vibro,
Unfortunately i feel you are trying to bait me which is a shame to be honest considering i thought we worked things out. clearly the op was happy with my contribution and did not find it confusing/wrong or anyhthing else your trying to imply.
I refuse to be drawn into your games and trying to be pedantic so lets just leave it there shall we.
