I have a question on Radiator Balancing. Can balancing radiators cause a boiler to kettle if the flow is restricted through each radiator by too much?
Additionally if a bypass valve is closed by too much can casue the same effect. My understanding is that if a bypass is open by too much then the boiler return will be heated more quickly, therefore the boiler will cycle more?
Is my understanding correct?
