I'm putting up some shelves onto plaster boarded walls and I'm confused. When you look on line for advice, it all seems to revolve around the type of fixing you use. They range from small generic yellow Rawl plugs, through Fischer specialist plaster board plugs to large spring toggles. It seems that you can hang anything off plaster board as long as you have a strong enough fixing.
But the plaster board itself is just stuck to the wall. I don't have any battens, so there are no screws. It's either sticky foam or more probably just plaster dabs. Don't you risk pulling the whole plaster board sheet off the wall eventually, or could I hang a grand piano with the right plaster board fixings. I'm not asking how to hang shelves. I'm asking how strong a large set of shelves would be with perfect fixings?
