Just wondering if anyone has practical experience of preventing condensation issues when fitting a bathroom. It's a semi detatched solid wall house and the room will have a brick party wall and internal stud/lath plaster walls ( originally a bedroom ). I have been reading the approved regs documents and have spoken to a couple of builders, its all different advice/warnings of condensation. I just want to make the job as simple as possible.
My proposal is to;
1. Party wall and internal stud walls. To comply with sound regulation. Remove plaster and get back to brick or the studding. Dot and dab 2 x moisture resistant plasterboard to the brick wall and fix the same to stud walls, have them skimmed over and paint. Where the shower is, I'll tank the boards
and then tile.
2. The outside wall. I'm told that Building Inspector will demand that insulated plasterboard be used here and i'm also told ( and read ) that there's a massive risk of condensation forming between back of boards and the wall. I suppose that even if I could dot and dab the 2 x moisture resistant boards, there would still be potential for condensation between the boards and the wall ??
3. Ceiling - I'm gonna leave the existing lath/plaster ceiling in and fix some battens to the plasterboards and form a frame to create a drop ceiling. I was going to fit PVC panels here. Again, I've read that I'll have to provide insulation above the panels, is this a condensation risk ?
4. Floor. Plywood and tile. If I have to bung a load of insulation between the joists, is this a condensation risk ?
The whole insulation thing seems a minefield on these old houses. Is it worth complying with the regs if it could potentially lead to condensation issues.
My proposal is to;
and then tile.
