- Joined
- 9 May 2013
- Messages
- 35
- Reaction score
- 0
- Country
can someone tell me some formulas to calculate the kW capacity for a cylinder coil.
which includes some or all of the following variables
• Length of coil
• Diameter of coil or Surface area.
• Material thermal conductivity
• Flow rate inside coil
• Temperature inside coil
• Temperature in cylinder.
I'd really appreciate if you can tell me various formulas to calculate that in different ways.
The only thing i know is that My cylinder has following specs
Store capacity 50L
Coil capacity is .28Litres
Diameter 18mm (external)
Material Copper
Thickness 1mm
max flow rate to be used 14L/min
I would try and answer any queries as much as i can.
Kind Regs
Gary
• Length of coil
Store capacity 50L
Material Copper
Thickness 1mm
Kind Regs
Gary
