I am looking for 2inch x 6guage brass screws but can,t find anywhere.(not in Screwfix catalogue) Can anyone help? Also are brass screws available with posi heads,as I can,t find these either. Thanks.
Try popping into your nearest electrical wholesalers, they should have them in stick. Somewhere like City electrical, Wholesale fittings, Edmundson (sp?). Alternatively try B&Q
Brass screws generally aren't available in PZD because they spelch-out too easily with power screwdrivers. To get a "brass" screw with a PZD all you will find is probably electro-brassed steel, and then only in a limited range of sizes. #6 x 2in are certainly available in steel (with PZD recesses) - the ones on my shelf are labelled "HFC" (or Huntingdon Fasteners) - but I can't recall seeing brass ones that length, presumably because they would be very prone to shearing. #6 x 1-1/4in seems to be as long as they go in solid brass.
Thanks everyone for your help,have now found these screws but in slotted heads. I have installed hardwood decking and 6 guage sits perfectly in the grooves. Originally used posi passivated steel screws but however carefull the plating is damaged by the power screwdriver bit on fixing thus exposing the bare steel. After only ten days these screws have stained the hardwood which looked dreadful. Stainless steel screws would have been ideal but stand out like a sore thumb agaist hardwood.
