Can\\\'t remove mixer Spout
4 Feb 2006
I have a kitchen mixer tap that has is leaking at the base of the swovel spout. I have removed the small grub screw and tried lifting/pulling the spout in all directions, but won\\\'t come out. What Am I doing wrong ? :?:
You're not pulling hard enough.
Do your best to position your chest over the top of the tap, and pull as directly upwards on the vertical part of the stem - if the stem isn't straight then it may not come out, but wiggling helps.
Also avoid getting your face in the way, just in case.
True, but this one has a grub screw, and with those type the position doesn't matter in my experience, but life is full of surprises...
