Can this handle be repaired or replaced?
Its called a cockspur handle.
Fixing holes should be standard, Hopefully yours are screwed and not pop riveted.
Only little problem you may run into is the stack depth. Measure off the frame to the edge of the plastic wedge to check. Worst comes to worst you can get different thickness's of those plastic wedges.
