I have wall lights that are run from two way switch and ceiling lights which are on normal circuit. Is it possible to wire the ceiling lights into two way circuit using a loop from wall light to ceiling - using a two gang two way switch.
That was my thoughts but worth asking.
I tried every which way to wire the ceiling into the two way circuit and just couldn't get it to work. Have now just wired the ceiling lights as if ordinary switch which is bizarre as the same config should have worked on two way.
