Is it ? How large is the surface area of the heat exchanger in the boiler ?Surely that's still less wasted heat than that given off by the huge surface area of a DHW cylinder, even with lagging?Newer ones are getting better - but you cannot get away from the fundamental problems they have. Unless they fire up (wastefully, as this BG one has the option of doing) periodically then there's a delay getting hot water.
It's only wasted if you don't use it. Interestingly my parents airing cupboard doesn't seem to get as hot as you might expect. That reminds me, I keep meaning to ask a mate about borrowing his thermal camera ...
Indeed. Suggesting that because a manufacturer is having problems (or in this case has gone belly up) that this indicates a fundamental problem with the product category is daft. If you take that line, then cars are a daft idea (look at the problems (for example) Ford were having recently, and the number of manufacturers that have disappeared over the years), and given the number of property developers that have gone bely up then that must show that houses are a daft idea. In the case of DPS, I thought their prices were too high for what they offered, and their marketing was poor - talking to them I got the impression that they didn't really know what they were selling since one person would offer me an option which later turned out not to exist.i think alot of these cylinder manufacturers were hoping to do well out of a renewables boom but it hasnt really happened.DPS seem to be having problems also......
http://tinyurl.com/4xt77g3
Though their website is still up and running.
I'd argue that they have a benefit whatever the size of the property. "Instant" mains pressure DHW vs delay while boiler fires up, optimised flow in rad circuit vs optimised flow through boiler, backup via immersion heater vs no backup. That's the benefits, the downsides are the cost, space required, and plumbing. That last of those never seemed to bother anyone when open vented DHW cylinders were the norm, but I'll accept the other two. Everything is a compromise - my personal opinion is that a combi is several compromises too far, and the primary reason for their popularity is that developers like the way they can build ever smaller shoeboxes. The house has an airing cupboard heated by a radiator - what was that about wasted heat from a hot cylinder again ?My personal opinion is that there is no benefit of thermal stores in small/average sized domestic applications unless its to utilise renewables/multifuel purposes and up til now its only really new builds they get specd, hence why Gledhill run into trouble in the recession.
Oh yes, and did I mention the varying DHW temperature ? Again it's something that's improved, but even on this relatively modern boiler and fairly modern thermostatic shower, you can still sense the variations in the shower.
But all this has somewhat diverged from the original topic, and is covering old ground which I'm sure is likely to lead to the same lack of agreement.
