Can you have a boiler near the gas meter?
17 Jul 2011
North Kent
Hello, id like to place the boiler and meter as close as possible (on each side of a cavity wall).
So I wondered if anyone knows if there's a minimum measurement they have to be apart? Cheers
And on a standard meter its is recommended a minimum distance of 150mm from any flue or opening
Yes, but no minimum distance from a boiler subject to flue clearance.
so there is a minimum distance glad we cleared that up.
And it says 150mm in link so if there is no minimum distance in MI`s you go by that and some MI`S had 100mm in boiler flue distances when a plume kit was used so you would go with 150 as per the link
you know fine well the guy would be talking about the flue outlet not the actual boiler inside the building
I didn't read it that way, he asked if it was ok to put have the boiler back to back with a meter on a cavity wall.
Apologies if I misunderstood.
i may also have read it wrong but i cant see why anyone would ask that
This is what I understood the question to be as well
