    Dismiss Notice
Can you pierce the main drain when gardening?
Discussion in 'In the Garden' started by boosh2000, 27 Feb 2008.
  1. boosh2000
    boosh2000
    19 Jan 2008
    15
    Thanks Received:
    Yorkshire
    Country:
    If digging just a foot - 18 inches down is it possible to put a garden fork through the main drain? And how would you know it had happened?
    I was digging my front lawn and about 8" down pirced some yellow plastic with stones and stuff underneath. I haven't done much more investigation, but I would like to know if I might have put my fork through my main drain.
  2. Sponsored Links
  3. bobby spray
    bobby spray
    23 Oct 2007
    162
    Thanks Received:
    10
    Stirlingshire
    Country:
    yes it is. And you'd know by looking
    If it's plastic you can fix with a collar or maybe some denso tape. Whatever you do do not leave it. if it's breached, it can fill up with soil and block = headache.
  4. JohnD
    JohnD
    15 Nov 2005
    69,636
    Thanks Received:
    3,905
    Crossgates
    Country:
    Cook Islands
    you say you pierced some yellow plastic with stones underneath
    was it a pipe or a piece of plastic marker tape?
    if it was yellow plastic pipe this is very serious as it sounds like gas pipe.
  5. boosh2000
    boosh2000
    19 Jan 2008
    15
    Thanks Received:
    Yorkshire
    Country:
    It's definitely not gas (fortunately) because we don't have a gas supply in the village.
    It was a flat yellow plastic sheet about a foot under where the lawn used to be and there seemed to be rubble underneath it (but the there's a lot of rubble in the ground anyway).
    I suppose I'll have to dig around it and have a proper look.
    If it's clay pipe I guess it would be a huge job.
  6. nstreet
    nstreet
    22 Nov 2003
    1,761
    Thanks Received:
    2
    Country:
    If you have heavy clay soil it may be some sort of land drain going to a sump, but yellow pipe is normally reserved for gas.
    If you have pierced black or brown pipe it could be for the soakaway from the gutters.
  7. JohnD
    JohnD
    15 Nov 2005
    69,636
    Thanks Received:
    3,905
    Crossgates
    Country:
    Cook Islands
    broad yellow plastic tape is laid over buried pipes and cables as a marker warning people who are digging,
    Assorted plastic and other rubbish is buried by builders as a way of annoying future homeowners.
    It would be a great help if you showed us a pic.
  8. Thermo
    Thermo
    21 Oct 2004
    9,979
    Thanks Received:
    149
    Sussex
    Country:
    And to annoy landscapers! Dont forget brick bats, wall ties, wall insulation, tin cans etc etc
    I doubt its a main drain. They will normally be deeper and if its near the surface, they tend to be encased with concrete (well older ones do). It is however perfectly possible to pierce them then, however you really need to do the job properly, as my apprentice did yeterday with a breaker, several times. Just after 8 in the morning, on a live run. I made him clear out all the debris, just as many people were getting sorted to go to work. I think he may think twice after that!
  9. Softus
    Softus
    21 Oct 2004
    19,558
    Thanks Received:
    12
    Country:
    [​IMG]
  10. Sponsored Links
  11. Thermo
    Thermo
    21 Oct 2004
    9,979
    Thanks Received:
    149
    Sussex
    Country:
    yes one of those will do the job nicely
  12. noseall
    noseall
    2 Feb 2006
    41,120
    Thanks Received:
    2,567
    Staffordshire
    Country:
    ouch!
    yellow plastic?
    is it ribbed and perforated?
  13. Thermo
    Thermo
    21 Oct 2004
    9,979
    Thanks Received:
    149
    Sussex
    Country:
    Dont look at the picture Noseall......DONT LOOK! :LOL:
  14. noseall
    noseall
    2 Feb 2006
    41,120
    Thanks Received:
    2,567
    Staffordshire
    Country:
    i..i..feel...sick.
  15. boosh2000
    boosh2000
    19 Jan 2008
    15
    Thanks Received:
    Yorkshire
    Country:
    :rolleyes: I've just dig it all to have a look and covered it up again. :LOL:
    I don't think I've damaged anything severely.
    It is in a line from where the drainpipe drains and the pavement. The garden (and the house) is raised from the pavement by a couple of feet.
    Halfway across the garden, about 10 or 12 feet from the house, about 10 inches down, there's yellow plastic sheet. Underneath the sheet is compacted rubble, but not compacted like a path - it has gaps between the stones. Looking underneath where I've put the hole in the sheet I don't seem to have particularly disturbed this rubble and the sheet stops about 8 inches on from where I'd started digging, continuing towards the house under earth I hadn't disturbed.
    If you'd like a picture I can dig it up again and take on, but am I worrying about nothing?
    I'll stress, the yellow plastic isn't a pipe, I'm just worrying that when I stuck my garden fork through it it was signifying not to dig past it.
    Thanks for all the help everyone. I worry very easily.
  16. noseall
    noseall
    2 Feb 2006
    41,120
    Thanks Received:
    2,567
    Staffordshire
    Country:
    you have discovered a storm drain and it leads to a classic soakaway. ;)
  17. boosh2000
    boosh2000
    19 Jan 2008
    15
    Thanks Received:
    Yorkshire
    Country:
    Phew! (Is that right? :) )
    So I've been worrying about nothing? I was beginning to think this might be a soak away because the soil pipe and other drains run away behind the row of houses (I know because I've had to blast them clear with a hose before now). I'd just managed to convince myself when I saw the plastic sheet and my garden fork sinking through, that I'd done something really stupid.
    So glad that I'm in the clear and thanks so much for all your help everyone.
  18. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
