Can you tell me what this part is please?
Status
Not open for further replies.
could be just one of these you need http://www.amazon.co.uk/Plumb-Pak-Compression-Blanking-Nut-4in/dp/B0039823M8 but when you get a leak always check to see if there's a leak further up that's dripping down, the valve is for the filling loop and the valve has been left open,turn the black knob to the right a quarter turn to switch it off
The valve is not for the filling loop, its the flow out of the boiler. Dont switch off unless you want to drain boiler and then switch off both flow and return.
Interested to know how she get's any heating with the flow capped off then ??
You think it's capped off? You are wrong. That is an integral part of the valve.
the flow goes through the wall like the first gloworms they brought out ?
The first Glow worms only had one valve. It was on the gas.
Jeff[/QUOTE
must have been an earlier model then than the ones I fitted in the early eighties,they had back entry valves which was easy to fit if you went through the wall with the pipes,but our company wouldn't supply street elbows if we had to drop the pipes, so we had to solder out of position otherwise the nuts on the valve would solder as well,though not to difficult as there was a jig
It may be leak from the nut above as suggested.
But the bottom plate of the boiler looks badly rusted and it should be inspected inside for further leakage.
The nut on the front of the valve is a blanking nut and the one on the return usually contains a gauze filter. But sometimes they are wrongly placed on the flow and sometimes the gauze is missing.
Thanks for the replies. Yes, we do have heating. That's great if it's just a washer - I'll task Oh with having a go at it first then
don't get sold a tap connector fibre washer there to small
529386
Status
