Can you used speedfit fittings and liners with hep2o pipe
6 Feb 2010
Blackpool
Can you used speedfit fittings and liners with hep2o pipe, the speed fit liners are very tight to get in the hep2o pipe.
Fittings yes, but I would use the correct inserts - that is, the same make as the pipe.
I would say yeh for both, but if something goes wrong don't expect the insurance to pay for it as it will be incorrectly installed.
always use the correct inserts though other fittings can be used.
personally I would use the correct pipe/fittings/inserts a leak can be much more expensive than correct fittings
You can mix and match fittings and pipe but the warranty on both will be invalidated, best to use the same manufacturer for both.
25mm Plasson will fit 25mm pipe
Speedfit will go straight onto copper
If you do use speedfit on copper, make sure you cut the pipe with a pipe cutter, not a hacksaw.
