Can you??
29 Jul 2005
hi all,
I'm new to decorating and so I wanted to know can you use bathroom tiles directly on plaster board? If so what do I need? does it have to be primed with something. Thank you in advance
Joesam
Yes you can tile straight onto it. Primer will not help the bond but will give you more working time as the water in the adhesive will be absorbed at a slower rate. Use the correct primer for the make of adhesive you use.
Jason
