This is one perhaps for zipper if your out there? Our dishwasher worked fine up to june then afetr one wash we had no LED lights on the programer. Checked everything, door switches, cable connections, and continuity checks. Left machine plugged in and then just before christmas opened the door and the LEDs were working again! Cleaned the machine out and started to use it again fine until today. Same thing again no LED display.
Is there any type of pressure switch which might get clogged up, cut the power supply and then once dried out again resets itself allowing current to flow. Or is it going to be the expensive PCB with a mind of its own.
Any ideas/tips on what to look at next will be most welcome.
